KB80796
Published: June 25, 2010
Upper Scaled Units incorrect for SNAP-AIRTD-10 Generic Point Type in PAC Manager
PAC Manager
Problem was discovered in version: R8.5a
Problem is fixed in version: R8.5b
The incorrect Upper Scaled Units value for a SNAP-PAC-AIRTD-10 is displayed in PAC Manager's Inspection window (Tools > Inspect, Point Config) when the Generic input Point Type is selected. The value displayed is 400 (Upper Scaled Units) instead of 25.
Change the Upper Scaled Units by clicking on the Value field for Upper Scaled Units, type in 25, and click Apply. Store this new configuration to flash by clicking Status Write, select Store configuration to flash, and clicking Send Command.
