KB80866
Published: June 25, 2010
Large Fonts affects screen displays in PAC Manager
PAC Manager
Problem was discovered in version: R8.5a
If the Windows large DPI display option is selected (font size appears larger), then some dialogs in PAC Manager display poorly.
For example, in Windows XP the setting is found in: the Control Panel > Display > Settings > Advanced Options > DPI setting--Large size. In Windows Vista, the Adjust font size (DPI) option is found under Control Panel > Personalize appearance and sounds.
