KB80890
Published: June 25, 2010
'Address of value to check' field in Alarm Events dialog may be cleared
Problem was discovered in version: R8.5a
Problem is fixed in version: R9.0a
The Address of value to check field in the Alarm Event dialog is cleared if the field is active, a change is made to the value, and the Enter key is pressed. The value is cleared and the focus shifts to the field on the left.
After entering the value in the Value field, use your mouse to click on another field. The number in the Value field is retained.
