KB80896
Published: May 12, 2010
Strategy on microSD card with Comment (Block) command stops executing
Problem was discovered in version: R8.5a
Problem is fixed in version: R8.5c
If a PAC Control strategy has the Comment (Block) command (in OptoScript: /* block comment */) and the strategy is downloaded from a microSD card to a controller, the strategy stops downloading when the comment code is encountered. If the same strategy is downloaded to a controller from a computer, the strategy downloads without a problem.
Remove the Comment (Block) command, or from OptoScript, the comments between /* and */, from the strategy.
