KB80899
Published: June 25, 2010
PID loop with a phantom output does not work on B3000-B
B3000-B
Problem was discovered in version: R2.9a, firmware file version
Problem is fixed in version: R3.2a, firmware file version
A PID loop on a B3000-B configured with a "phantom output" (an output position on a rack that does not actually have an analog output module installed), does not work correctly. The output value remains at zero instead being set to the correct output value.
