KB80910
Published: June 25, 2010
B3000-B communications disabled after receiving certain I/O commands
Problem was discovered in version: R2.9a, firmware file version
Problem is fixed in version: R3.2a, firmware file version
Communication from a controller to a B3000-B is disabled if the OptoControl commands Clear I/O Unit Interrupt (I/O unit command zA) or Clear Event Latch (I/O unit command zB) or the I/O unit command Get Event/Reaction Status (zC) is sent to the I/O unit.
