KB80947
Published: June 25, 2010
PAC Display Pro reports error at Runtime if string tables in FactoryFloor strategy are used
Problem was discovered in version: R8.2m
Problem is fixed in version: R9.0a
A problem is reported by PAC Display at Runtime if the project uses string table tags in an OptoControl strategy. Error 0xC0040008 is reported in the Event Viewer when entering Runtime, and values for the tags are not displayed. You may also notice that the tag name displayed in the event viewer does not have the correct syntax.
