KB80951
Published: June 25, 2010
Clear All Event Latches command resets B3000-B digital addresses
B3000-B
Problem was discovered in version: R3.0, firmware file version
Problem is fixed in version: R3.4a, firmware file version
The digital addresses of a B3000-B reset after the Event/Reaction command Clear All Event Latches command (I/O command 'Q') is used to clear all event latches. The reset occurs for a short period of time after the command is executed.
