KB80972
Published: July 16, 2010
Negative Decimal Values between 0 and -1.0 not allowed for some Control Engine Driven Dynamic Attributes
Problem was discovered in version: R98.2m
Problem is fixed in version: R9.0c
If a negative decimal value between 0 and -1.0 is used when configuring a control engine driven dynamic attribute, a Value Error balloon appears and reports that the Integer not within required range: -2147483648 < = value < = 2147483647. It should permit a negative decimal value to be entered.
The following Dynamic Attribute dialogs cause this message:
Fill Color / Line Color
Visibility / Blink
Horizontal / Vertical Position
Horizontal / Vertical Size
Rotation
