KB80987
Published: June 14, 2010
InfoKB: Incorrect termination switch settings for B3000-B
Problem is fixed in Technical Note: Form 1927-100609
Version 1927-100609 is June 9, 2010
Problem is fixed in User's Guide: Form 1781-100609
Version 1781-100609 is June 9, 2010
The Configuring the B3000-B Technical Note, form 1927, and B3000-B Serial Brain User's Guide, form 1781, incorrectly describe the RX switch setting when the B3000-B is used in a 2-wire RS-485 configuration and is at the end of the cable. The correct switch settings are:
IRQ = ON
RX = OFF
TX/RX = ON
