KB81012
Published: July 16, 2010
PAC Display Runtime Historic Log does not log String Tables correctly
Problem was discovered in version: R9.0b
If an Historic Log is configured to log string table ranges (not individual entries), then at Runtime an error message appears in the Event Log that says Referenced Type: String Table, Actual Type: String.
The following is an example of the Historic Log configuration that can cause this problem:
