KB81022
Published: July 28, 2010
Cannot type in negative Int32 literals in Add Instruction dialog
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R9.0d
Problem is fixed in version: R9.0e
When adding an instruction in PAC Control, a minus sign cannot be typed into the Name field for a type Integer 32 Literal.
Copy and paste a negative number into the Name field.
