KB81042
Published: August 23, 2010
BIT suffix added to non-integer variable when using Edit > Replace, 'Bit index' Offset command
Problem was discovered in version: R9.0c
Problem is fixed in version: R9.0d
If the Edit > Replace command in Configurator is used with the Offset By option, then other tags that are not integers, are modified within the tag field to appear as if they also have a BIT index.
For example, a graphic with assigned attributes is selected (sizing handles are visible around it). The Edit > Replace command is selected and configured so that the Chosen graphics will offset the currently configured bit index by 2. After clicking OK, if a float variable, for example Analog_Input_1, is also assigned to the graphic, the variable is changed to appear as Analog_Input_1.BIT02.
