KB81059
Published: August 23, 2010
PAC Control connection lines disconnecting from objects
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R9.0e
Problem is fixed in version: R9.0f
Flow connection lines can become disconnected from block objects in PAC Control configure mode. After creating flow chart strategy logic by using blocks and connection lines, attempting to move a connection line from an Action, Condition, or Script block, may cause the end point of the line to become disconnected from the block and show a line connected to empty space in the window.
Delete the disconnected line and redraw it.
