KB81080
Published: September 20, 2010
PAC Display's 'Edit > Replace' does not replace table names in table objects
Problem was discovered in version: R9.0e
Problem is fixed in version: R9.0f
The Edit > Replace menu option does not replace table Item Names for table graphic objects.
In the example below, the Find and Replace window specifies that Table_2 should be replaced with Table_1 for the table object called Received_Products. Clicking OK does not make the desired change.
