KB81083
Published: September 27, 2010
Error -95 returned from PAC Control subroutine with a Case or IF statement
Select Version Text R9.0a
Problem is fixed in version: R9.0b
Error code -95, the object is null, may be returned when a subroutine is called from a Case statement or an IF statement in an OptoScript block. The problem may occur when using the Debug tools (Step In, Step Out, etc.) prior to calling the subroutine. The control engine may possibly reset as a result of this problem.
