KB81084
Published: December 16, 2011
Subroutines from Case or IF statement may have unexpected results
Problem was discovered in version: R8.5d
Problem is fixed in version: R8.5e
If a PAC Control subroutine is called from a Case statement or from within an IF statement, it is possible the controller may exhibit unexpected behavior, including a controller reset.
IF Example:
if (CommStringLength > 0) then
     Status = CallMySubroutine();
endif
Switch Example:
switch ( ControlMode )
case 0:
     break
case 1:
     Status = CallYourSubroutine();
     break
endcase
