KB81095
Published: August 2, 2011
PAC Display Runtime may hang if Alarm Point tags are disabled
PAC Project Professional
PAC Project Basic
Problem was discovered in version: R9.0f
Problem is fixed in version: R9.1a
If an Alarm Point is Setup By a Current Value, and the value is a tag (not a literal value),
and the alarm point is then disabled in Configurator from the Alarming Setup (Configure>Alarming Setup),
then Runtime may hang when it starts up.
