KB81099
Published: August 2, 2011
Memory leak in PAC Display Runtime if logging String Tables in Historic Logs
Problem was discovered in version: R9.0f
Problem is fixed in version: R9.1a
If a Historic Log is configured to log String Tables, a memory leak occurs in Runtime. If there are many Historic Logs logging string tables, or string tables with many elements, the leak can rise sharply and be detected in Task Manager.
