KB81115
Published: December 6, 2011
Revision: 4.0
SNAP PAC control engine serial ports are always set to Parity=None
Problem was discovered in version: R8.5d
Serial ports on SNAP PAC control engines are always configured for "parity=none" (or "parity=n") if lower case letters are used for the parity setting, even if the communication handle string includes a different parity setting.
Use a capital "O" for odd parity, or "E" for even parity in the Communication Handle configuration string.
Example: ser:port=2,baud=9600,parity=E,data=8,stop=1,rts-cts=1
