KB81116
Published: July 22, 2016
PAC Control subroutine names with a space or dash generate a misleading error
PAC Control Basic
PAC Control Professional
Problem affects versions: All versions
When you create a subroutine in PAC Control and include a space or dash in the name, you see an error that says, "The subroutine name must start with a letter," even if the name does start with a letter.
Make sure your subroutines names do not contain spaces or dashes. You can use an underscore between words instead of a space or dash.
