KB81121
Published: December 20, 2010
Fewer I/O point options shown after moving a high density digital point in configuration window
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R9.0g
Moving a point on a high density module results in a reduced list of available I/O points. The scrollbar disappears and where once there were for example, 32 points available, only eight can be accessed.
To duplicate:
1. Open a PAC Control strategy in Configure mode.
2. In the Configure I/O Points dialog, add a high density module and point.
3. Move the point from one channel to another.
Not all I/O points on the module are displayed and the vertical scrollbar on the right may disappear.
Resize or close the configuration window. All I/O point options are correctly displayed, and the scrollbar reappears.
