KB81192
Published: August 2, 2011
Edit > Replace command does not make changes within a ComboBox in PAC Display
Problem was discovered in version: R9.0f
Resolution is included beginning in version: B9.0i, 1/28/2011 or later
Problem is fixed in version: R9.1a
In PAC Display Configurator, the Edit > Replace command does not work with tags that are used in a ComboBox. For example, if Edit > Replace is used to find a tagname to replace it with a different tagname, the tagname change is made throughout the project, but not to the tags used within a ComboBox object.
