KB81196
Published: August 2, 2011
Regenerate Scanner Tags command skips tags in ComboBox control
Problem was discovered in version: R9.0f
Resolution is included beginning in version: B9.0i, 02/02/2011 or later
Problem is fixed in version: R9.1a
The Tools > Regenerate Scanner Tags command in PAC Display Configurator does not process tags in a ComboBox control. As a result, PAC Display Runtime attempts to access information for the wrong tag.
Example: Suppose a ComboBox is assigned a dynamic attribute with a tag from Controller "A."
- Save the project.
- Modify the controller in the project (Configure > Controllers) to point to Controller "B." It appears as if the controller change is made.
- Save and run the project with File > Save Project and Load Runtime. The Tools > Regenerate Scanner Tags command is automatically run.
In Runtime, the ComboBox tag still attempts to access data from Controller "A."
