KB81204
Published: May 11, 2011
SNAP-PAC-S1 with R9.0c firmware does not boot if microSD card is installed
Problem was discovered in version: R9.0c
Problem is fixed in version: R9.1a
A SNAP-PAC-S1 controller with R9.0c firmware does not boot up if a microSD card is installed in the controller. When the controller is powered up, the STAT LED flashes green twice, resets, and repeats.
Remove the microSD card before the controller is turned on.
