KB81205
Published: April 5, 2011
PAC Display Runtime hangs when recipe file is downloaded
Problem was discovered in version: R9.0f
PAC Display Runtime hangs if a recipe with invalid tags is downloaded to the controller. The invalid tags are either misspelled tag names, or tag names that do not exist in the strategy.
Verify the tag names in the recipe file are correct by using Tools > Validate Recipe File in PAC Display Configurator.
