KB81213
Published: May 16, 2011
Invalid analog input readings for ~3 sec after power-up
OPTOEMU-SNR-3V
Problem was discovered in version: R9.0c
Problem is fixed in version: R9.1b
The OptoEMU-SNR-3V analog points return invalid values for up to 3 seconds after the unit is powered up.
Wait at least 3 seconds and not more than 5 seconds, before reading analog inputs to return valid values.
