KB81256
Published: April 6, 2011
Logrithmic SuperTrends with pen Minimum scaled <0.01 may cause Runtime problems
Problem was discovered in version: R9.0f
PAC Display Runtime may crash if a SuperTrend pen is configured as a logrithmic scale and is scaled for a value that is smaller than 0.01.
For example, suppose a SuperTrend is configured for logrithmic scaling and a pen is scaled for a minimum value of 0.001, and maximum value of 10. At Runtime, use the Active Pen Scaling Adjustment
to bring up the SuperTrend Pen Scale dialog. The dialog displays the minimum value as 0.00 instead of 0.001.
When the dialog is closed, Runtime may crash.
