KB81264
Published: August 2, 2011
Bit indices past 31 in Int64 table element are not changed by Edit > Replace
Problem was discovered in version: R9.0f
Problem is fixed in version: R9.1a
In PAC Display Configurator, the Edit > Replace command does not change bit indices greater than 31 in Int64 table elements.
