KB81265
Published: August 2, 2011
ComboBox element change is not saved
Problem was discovered in version: R9.0f
Problem is fixed in version: R9.1a
If an object in a ComboBox is changed with the Modify button, the orignal text is not changed.
Example: A ComboBox, has an element named Pump2. Use the Modify button to change the text to Pump3. Close the Modify Entry Text and the ComboBox Dynamic Attributes dialogs. Double-click the ComboBox. The modified ComboBox element has the original text, Pump2.
