KB81271
Published: August 2, 2011
Discrete write to Analog/Digital I/O Unit in Runtime causes error messages
Problem was discovered in version: R9.0f
Problem is fixed in version: R9.1a
If a Discrete Tag is setup with an Operator Driven Attribute to write to an Analog/Digital I/O Unit with the Enable field,
then error messages pop up at Runtime when the dynamic attribute is executed. The error messages may be similar to the following:
TValue::CopyFrom() ERROR
Referenced Type = null
The I/O unit is still enabled or disabled by the dynamic attribute.
