KB81302
Published: March 19, 2012
Problems with Ethernet communications after restoring controller Configuration Data from microSD card
Problem was discovered in version: R9.0c
Problem is fixed in version: R9.1d
Communication over Ethernet does not work after a controller's IP Settings and Configuration Data are restored from a microSD flash card.
To duplicate problem:
  1. Use the PAC Manager command Store Configuration and IP Settings to microSD.
  2. Remove the microSD card from the controller.
  3. Execute Restore to Factory Defaults.
  4. Insert the microSD and cycle power to the SNAP-PAC controller.
  5. Attempt to communicate over Ethernet to the controller (with PAC Manager, PAC Control, etc.), and the controller does not respond.
