KB81311
Published: July 29, 2011
'High Density Digital Input Module #' incorrectly displayed for Event in Configure Mode
Problem was discovered in version: R9.0c
Problem is fixed in version: R9.1a
The wrong Value type is displayed for an Event if for a previously configured Event, the High Density Digital State was configured for the Use which data for trigger #1? parameter.
To reproduce the problem, open a Configurator file, .cfg (File > Open), right-mouse click an I/O unit, click Configure > Events > Digital Events - Expanded. For the Use which data for trigger #1? parameter, select High Density Digial State. The following is shown:
If a different event is now selected, the High Density Digital Input Module # event is incorrectly displayed, as well as the incorrect Value type (a point mask instead of an integer) as shown in the following image:
