KB81341
Published: October 5, 2011
Time/Date set commands can sync stale data to the backup controller of a redundant system
Problem was discovered in version: Firmware R9.1b
Problem is fixed in version: Firmware R9.2a
In a PAC Control strategy, if you use a Time/Date command to set a value on the active controller in a redundant controller system, when the two controllers sync, the backup controller's clock may be out of date with the active unit.
When you use a Time/Date command on the active controller, follow the time change immediately with a sync block. That way the two clocks will remain in sync.
