KB81359
Published: August 3, 2011
High current and power readings by OptoEMU-SNR-3V using CTs
OPTOEMU-SNR-3V
Problem affects all units manufactured: July 2011 (07/11) or earlier
An OptoEMU Sensor with a "direct connection" to measure current and power using current transformers (CTs), is incorrectly calibrated and is reporting values that are 13.6% higher than actual values. The calibration problem affects all three phases (Phase A, B, and C).
