KB81365
Published: August 17, 2011
Fourth table in Table object appears cut off
Select Version Text R9.1a
Problem is fixed in version: R9.1b
If a Table object is added to a window and four tables are configured with Align Data set to Right, then at Runtime the values in the fourth table are cut off as shown below. Changing the width of the table in Configurator does not change the appearance of the table at Runtime.
