KB81382
Published: September 7, 2011
PAC Display prints only once, cannot be restarted
Problem was discovered in version: R9.1a
Problem is fixed in version: R9.1c
Attempting to print (File>Print) more than once from PAC Display Configurator or Runtime does not work. If PAC Display is closed, it cannot be restarted. If Task Manager is used to inspect Applications, PAC Display is still running.
It PAC Display does not restart, use Task Manager to end the PAC Display task that is running.
