KB81389
Published: August 17, 2011
PAC Display hangs when attempting to convert OptoDisplay project
Problem was discovered in version: R9.1a
Problem is fixed in version: R9.1b
From PAC Display Configurator and with no project open, selecting File > Convert Opto Display Project causes PAC Display to hang.
To work around this problem, close PAC Display Configurator and then manually run the conversion utility FAC2PAC.exe. This conversion utility is typically found in the folder C:\Program Files\Opto22\PAC Project 9.1.
