KB81410
Published: March 19, 2012
Serial port's baud rate not changed
Problem was discovered in version: R9.1b
Problem is fixed in version: R9.1d
Changing the baud rate for a controller serial communication port from a PAC Control strategy (such as with: SetCommunicationHandleValue(“ser:0,115200,n,8,1”, Ser_ComHandle);) sometimes does not take effect by simply downloading and restarting the strategy in the controller.
To work around this problem, cycle power to the controller so that the changes to the serial port baud rate takes effect.
