KB81431
Published: September 28, 2011
Renaming a tag or using Find and Replace within Tag Names causes OptoScript errors
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R9.1a
Problem is fixed in version: R9.1b
OptoScript code that contains a renamed variable or where the Find and Replace within a Tag name feature was used, may become corrupted. The OptoScript code may be missing several characters as a result of the change. This only affects OptoScript blocks that have many (hundreds) lines of code and that contain the modified variable.
