KB81443
Published: December 22, 2011
Modbus/TCP, IO4AB, and SNMP 4-channel data may be old
SNAP-PAC-EB1
SNAP-PAC-EB2
SNAP-PAC-EB1-W
SNAP-PAC-EB2-W
SNAP-PAC-SB1
SNAP-PAC-SB2
Problem affects versions: R8.1a through R9.1c
Problem is fixed in version: R9.1d
Four-channel digital input and output states and/or feature values (such as counter values) may stop updating This can first occur 24.85 days after the unit was powered up. It can then occur at 49.7 day intervals after that.
The problem does not occur when using OptoMMP protocol to communicate with the I/O unit, such as when a SNAP-PAC controller or OptoOPCServer communicates with the I/O unit. It is only possible for this problem to occur when using the following protocols, while not using OptoMMP protocol:
- Modbus/TCP
- Ethernet/IP
- SNMP
