KB81451
Published: December 2, 2011
An Up Timer is not working as expected
Problem was introduced in version: R9.0a
Problem is fixed in version: R9.1d
If a target time has not been set for an Up Timer and the condition Up Timer Target Reached? is used in a Condition block, then the Condition block exits true. All firmware versions prior to R9.0a, however, would exit false. This causes a problem for strategies developed with firmware versions prior to R9.0a because the PAC Control strategy logic is expecting the same behavior.
