KB81503
Published: October 14, 2011
PAC Control may not open PDF with default PDF viewer
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R9.1b
Problem is fixed in version: R9.1c
PAC Control might not use the current default PDF viewer when opening a PDF. It may use registry enties that refer to another PDF viewing application that was used prior to the current default PDF viewer.
