KB81511
Published: October 14, 2011
Some error messages are missing from PAC Project Software R9.1
PAC Project Professional
PAC Project Basic
Problem was discovered in version: R9.1a
Problem is fixed in version: R9.1d
New error messages introduced by PAC Project firmware R9.1a were not included in the PAC Project Software Suite.
The missing error codes are:
-110   The microSD card is missing.
-111   The hardware doesn't support this feature.
-112   NVRAM is corrupt; battery may need to be replaced.
-449   FTP: error while setting local port number that incoming data connections should use.
-450   DNS could not resolve host name to an IP address.
-451   SMTP: Login failed.  Check username and password.
-452   File already exists.
-453   Invalid pathname or drive specification.
-454   Unable to connect to DNS server. Check DNS and gateway configuration.
-2000   PKI: Bad certificate
-2001   PKI: Certificate revoked
-2002   PKI: Certificate expired
-2003   PKI: Certificate unmatched
-2004   PKI: Certificate signed by unknown CA
-2101   SSL: Client start failure
-2102   SSL: Write stream flush failure
-2103   SSL: Handshake failed
-2104   SSL: Handshake failed due to invalid or unverifiable certificate
-2105   SSL: Unspecified asynchronous platform errorbr
-2106   SSL: SSL session is not open
