KB81597
Published: March 14, 2012
Moving an Int64 into a timer in an Action block causes reset
PAC Control Professional
PAC Control Basic
Problem was discovered in version: R9.1a
Problem is fixed in version: R9.2a
In PAC Control, if the Move command is used in an Action block to move an integer 64 literal or variable into a timer variable, then when the Move command is executed, the controller resets.
To work-around this problem, move a float or integer 32 value or variable into the timer, or use OptoScript to move the integer 64 value or variable into the timer.
