KB81645
Published: March 14, 2012
Redundant system I/O units don't re-enable if they are rebooted
Problem was discovered in version: R9.0a
Problem is fixed in version: R9.2a
In a redundant system, an I/O unit that reboots and loses its configuration cannot be communicated to and re-enabled by a controller because the I/O unit is not configured. The controller must be rebooted so that the I/O unit can be configured by the controller.
The work-around is to store the I/O unit's configuration to flash so the it will always be configured when it boots up.
