KB81668
Published: November 30, 2011
Some redundant controllers cannot be turned off separately
Problem affects redundant systems from: April 2010 through
November 2011
Problem is corrected beginning: November 2011
Some redundant controllers cannot be turned off separately and can only be turned off at the same time. This problem may also cause both controllers to be in the active state at the same time.
