KB81908
Published: March 22, 2013
'Send Email With Attachments' command result code may be incorrect
Problem was discovered in version: R9.1a
When sending email with attachments, the returned Result for the Send Email with Attachments command is based upon which attachment was successfully sent. The Result should return the number of attachments successfully sent.
Example:
Two files, file1.txt and file2.txt are to be sent in an email. If file1.txt is not sent and file2.txt is sent, the command's Result returns 1, showing that one attachment was successfully sent. However, if file1.txt is sent and file2.txt is not sent, error -407 (File not found) is returned, even though file1.txt was successfully sent (Result should return 1).
