KB81913
Published: November 14, 2012
"Enable I/O Unit" overwrites replicated MMP PID tuning parameters on Redundant Systems
Problem was discovered in version: R9.1a
On a redundant controller system, changes made to PID tuning parameters may be overwritten with the originally configured values if the system switches to the redundant controller and the Enable I/O Unit command is used. The problem only occurs if the PID tuning parameter values were changed by directly modifying the values in the OptoMMP Memory Map locations.
