KB81962
Published: November 1, 2012
The PAC Control HTTP commands may return wrong error when connection fails
Problem was discovered in version: R9.1a
The HTTP commands may incorrectly return error -438 Socket creation error, instead of the -412 Socket connect error when a connection fails. Connection failures can be caused, for example, by servers being down or by using the wrong IP address.
The HTTP commands are:
  • HTTP Get
  • HTTP Post Calculate Content Length
  • HTTP Post from String Table
